PPO Training does not improve SFT model outputs (Metrics identical before and after PPO)
Hi All,
I’m currently facing an issue where applying PPO training using trl==0.11.3 on top of my SFT model seems to make no difference at all in the final evaluation metrics. Here’s a snapshot of the comparison before and after PPO:
=== Summary Metrics ===
| model                     | exact_match | rouge1_f1 | rouge2_f1 | rougeL_f1 | bleu     | meteor  | inference_time_sec |
| SFT-SeaLLMs-v3-7B-LoRA    | 0.0428571   | 0.657684  | 0.524886  | 0.618101  | 0.418482 | 0.6555  | 46.5213             |
| PPO-SFT-SeaLLMs-v3-7B-LoRA| 0.0428571   | 0.657684  | 0.524886  | 0.618101  | 0.418482 | 0.6555  | 42.8529             |
:red_question_mark: Issue
Although the PPO loop runs successfully, the final model appears to behave identically to the original SFT model. Rewards do vary across training steps, and no errors are raised. Yet, the downstream generation quality remains unchanged.
Below is the full training code I’m using (compatible with trl==0.11.3 ):
#!/usr/bin/env python
# Compatible with trl==0.11.3
# Launch with: accelerate launch --config_file accelerate_config_ppo.yaml train_ppo.py
import os
import json
import math
from functools import lru_cache
import torch
import numpy as np
from datasets import load_dataset
from transformers import AutoTokenizer
from trl import (
    set_seed,
    PPOConfig,
    PPOTrainer,
    AutoModelForCausalLMWithValueHead,
    create_reference_model,
from trl.core import respond_to_batch
from openai import OpenAI
from tqdm.auto import tqdm
SEED = 42
MODEL_NAME = os.getenv("POLICY_MODEL", "../sft/sft_mp_final")
DATA_PATH = os.getenv("DATASET_PATH", "../datasets/cqa_ppo.jsonl")
LOG_DIR = os.getenv("LOG_DIR", "trainer_output/ppo_logs")
OUTPUT_DIR = os.getenv("OUTPUT_DIR", "ppo_model_final")
set_seed(SEED)
torch.manual_seed(SEED)
torch.cuda.manual_seed_all(SEED)
ppo_cfg = PPOConfig(
    model_name=MODEL_NAME,
    learning_rate=1e-5,
    batch_size=1,
    world_size=8,
    mini_batch_size=1,
    seed=42,
    ppo_epochs=1,
    kl_penalty="full",
    log_with="tensorboard",
    project_kwargs={"logging_dir": LOG_DIR},
tokenizer = AutoTokenizer.from_pretrained(MODEL_NAME, local_files_only=True, use_fast=True)
if tokenizer.pad_token_id is None:
    tokenizer.pad_token_id = tokenizer.eos_token_id
policy_model = AutoModelForCausalLMWithValueHead.from_pretrained(
    MODEL_NAME, torch_dtype=torch.float16, local_files_only=True
ref_model = create_reference_model(policy_model)
raw_ds = load_dataset("json", data_files=DATA_PATH, split="train").select(range(10))
def process_data(raw_ds):
    def make_prompt_response(example):
        prompt = f"{example['context']}\n\nPertanyaan: {example['question']}\nJawaban:"
        response = example['answer']
        return {'prompt': prompt, 'response': response}
    return raw_ds.map(make_prompt_response, remove_columns=raw_ds.column_names)
processed_ds = process_data(raw_ds)
@lru_cache(maxsize=None)
def score_response(prompt: str, response: str, reference: str) -> dict:
ppo_trainer = PPOTrainer(
    config=ppo_cfg,
    model=policy_model,
    ref_model=ref_model,
    tokenizer=tokenizer,
generation_kwargs = {"top_k": 0.0, "top_p": 1.0, "do_sample": True}
device = ppo_trainer.current_device
for step, sample in enumerate(tqdm(processed_ds, desc="PPO Training")):
    prompt = sample["prompt"]
    reference = sample["response"]
    input_ids = tokenizer(prompt, return_tensors="pt").input_ids.squeeze(0).to(device)
    out = ppo_trainer.generate(input_ids, **generation_kwargs).squeeze(0)
    new_tokens = out[input_ids.shape[0]:]
    response_str = tokenizer.decode(new_tokens, skip_special_tokens=True)
    metrics = score_response(prompt, response_str, reference)
    reward_val = metrics["reward"]
    reward_t = torch.tensor(reward_val, device=device)
    stats = ppo_trainer.step([input_ids], [new_tokens], [reward_t])
    tqdm.write(f"Step {step:3d}: reward = {reward_val:.4f}")
# Save the final PPO-tuned model
os.makedirs("ppo_fine_tuned_model", exist_ok=True)
ppo_trainer.save_pretrained("ppo_fine_tuned_model")
If anyone sees anything that might explain why PPO is not affecting the model outputs, I’d really appreciate your help. Thanks in advance!
Hmm… That’s a pretty old version of TRL…
In any case, it’s unlikely that the model output would remain completely unchanged, regardless of whether the fine-tuning was successful or not. I think the process of rewriting the tensor is either not being performed or is failing. Or maybe some processing is missing.
If the same code works with other models, then perhaps the layers are frozen or set to non-trainable…
